Re: Casting?
Here's the money quote in that link:
His formula seems similar to the alumina formula James gives:
It sounds like it would be difficult and unsatisfactory. If you do this, please keep us informed. We're always open to learn new techniques.
I did not use wire for my most recent castable shell and there is severe cracking — though the cracking is not structural.
In between Refrax and fire clay/Portland cement mortar, you can make your own aluminate mortar. It is hard to work with, as calcium aluminate can be challenging. If you get the mix, or water wrong, it won't set correctly. It partially sets very quickly, and you cannot re-hydrate it, so you have to mix it and use it in small batches. Still, if you are trying to save money and want/need the heat resilience, heat conductivity and longevity of a true aluminate mortar, it works.
1 part calcium aluminate
3 parts sand
1 part lime
1 part fire clay
3 parts sand
1 part lime
1 part fire clay
