Cleaning the bricks : alternatives
  • MarkDLxu
    • May 2020
    • 57
    Good morning,
    I’m halfway in building my oven and I noticed some bricks, as well as the floor, are a bit dirty by the mortar or have a thin layer of water/mortar coming from the bricks above.
    A part from use water & patience, or diluted muriatic acid that I think it’s very corrosive,
    Is there a solution in between the two ?
    thanks for the advice ,
    Marco
  • SableSprings
    Moderator
    • May 2009
    • 1310
    Marco, try using vinegar to remove the light mortar residue. Some people make a dilute solution with water (50/50), but try just putting some white vinegar on a damp cloth and wiping the mortar "tears". Hope that helps...
    Roseburg, Oregon
    • MarkDLxu
      • May 2020
      • 57
      Thanks Mike,
      what i did is vinegar , soapy water and a lot of metal brushes ...
