I have a Forno Bravo Casa90 kit installed. I did some calculations and figured out that in order to take the oven up to pizza temperature, about 0.7% of the energy burned out of the oak ends up stored in the walls/floor,. The rest, 99.3%, must go up the chimney or out the front door (very little escapes through the dome). A few details of this calculations are below.
My question is - does a really low efficiency sound right to people? I guess I'm surprised it's so inefficient. What kinds of things can we do to improve that? For example, I hadn't previously insulated my chimney, it's just exposed metal, is that bad?
Does any particular configuration of the startup fire work better for efficient energy delivery to the dome? I usually try to make a fire that's not too wide but fairly high so the flame hits the dome directly and rolls along it as much as possible.
What if one kept the door closed but then had a small opening and had some kind of fan pumping air in to feed the fire? Anyone ever try something like that?
Improving that 0.7% number would dramatically speed up the heat-up process and/or require much less wood.
Calculation:
I have a Casa90, 2" thick walls and 36" diameter dome. I estimated the specific heat of FB refractory concrete to the 690 J/Kg/K based on the materials composition they posted. From that I get 61 MegaJoules of energy to bring temp from 20 C to 500 C. I assumed oak heat density of 91 trillion Joule per m^3, and that I use 0.09 m^3 of wood (or, 2.5% of a cord) to get the oven up to temperature, so that's 8.3 GigaJoules of energy burned.
It's possible I got something wrong but I've checked it over a few times.
Calculation:
