Best way to clean mortar off stone & Brick?
  • Rockwallgriller
    • Jun 2008
    • 34
    Just wondering the best way?
    Thx.
    B
  • thebadger
    • Jun 2007
    • 383
    Re: Best way to clean mortar off stone & Brick?
    Rockwallgriller
    The posts Ive seen said to use "muratic" acid if the mortar is really dried/set. Pretty scary stuff. I think I might try to use it on my outer decorative arch...
    Dick
    • Ed_
      • Apr 2008
      • 139
      For what it's worth, muriatic acid is another (older) name for hydrochloric acid. We probably all used it in high school chemistry class, so while some caution is warranted, it's not that scary.
      Gloves, goggles, and old clothes for sure.
      • Chef
        • May 2008
        • 175
        I used a pressure washer, but I was SUPER careful not to let the high pressure stream hit the joints.
        Malinda
        Check out our blog for a glimpse into our hobbies of home brewing, soda, beer and wine, gardening and most of all cooking in our WFO!
        http://thereddragoncafe.blogspot.com/
          Make sure you dilute the hydrochloric acid. About 15:1 I think
          • Rockwallgriller
            • Jun 2008
            • 34
            I've read it's 10:1 ratio....
            Then what? Spray on let it sit then scrub with wire brush, then wash off with garden hose?
            • thebadger
              • Jun 2007
              • 383
              Still scary stuff to me... I can never remember which to add first, water or acid. For that matter, I can't remember which battery cable to hook up first...
              Dick
              • asudavew
                • Jul 2007
                • 1880
                Dick
                Do your remember which to lay first?
                Brick or mortar?
                Is that like the chicken and the egg thing?
                My thread:
                My costs:
                My pics:
                • asudavew
                  • Jul 2007
                  • 1880
                  I would like to know the answer too!
                  My thread:
                  My costs:
                  My pics:
                  • SpringJim
                    • Apr 2008
                    • 562
                    Clean it off while it's wet...use a sponge with a scrubbie on the other side or a scrub brush!
                    OK ok....it's hard and you want it off.
                    Understand that the muriatic / hydrochloric acid is dissolving the mortar by chemically attacking it. It should not impact the firebrick since it's vitrified. You put the chemical on the mortar and let it do it's work. It will dissolve it from the outside in. Using a scrub brush will help remove the outer layer of mortar (sand) and let the acid work it's way down. It's actually fizzing.....make sure you don't have any limestone or marble nearby!
                    Rinse it off when done.
                    Goggles and gloves for sure!
                    • rafv
                      • Feb 2008
                      • 36
                      Try a wire brush on its own first. If it does not get it all off at least you wont need so much acid. If you do use acid, as well as goggles and gloves protect your clothes. Or wear something that you do not mind ending up full of holes. You will not notice the holes straicht away but the first time you wash your clothes!!!
                      sigpicNever put off untill tomorrow what you can do today. If you enjoy it today, you can do it again tomorrow.
                      • RTflorida
                        • Jan 2007
                        • 1446
                        I wouldn't recommend the use of acid on the inside of a completed dome...your going to end up wearing as much of it as you get on the bricks.....acid burns to the hands are tolerable, the face, neck and torso are another story - you don't want to go there.
                        On the inside - scrape or brush all you can and don't worry about the rest....few people will ever see it. Other than myself, no one has ever stuck their head in my oven to look around...everyone seems content just watching from a safe distance when I'm firing or cooking and my door is always in place when not in use.
                        RT
                        • Groves
                          • Jun 2008
                          • 46
                          just fyi, you add acid to the water. not water to the acid.
                          • SpringJim
                            • Apr 2008
                            • 562
                            Thx.
                            B
                            Stone and brick.....
                            Are you talking about an oven dome or other masonry work?
                            • Rockwallgriller
                              • Jun 2008
                              • 34
                              No oven, just the out side of my grilling area, installing rock to the sides and I am getting some mortar on the face a little. I'm trying to be more careful as I go.
                              Thx
                              B
