Heat Proof silicone
  • G_ReG23
    • Mar 2023
    • 2
    Heat Proof silicone
    Hi all,
    I have a brick pizza oven with a cast concrete arch at the front.
    Due to different expansion rates, the concrete arch always comes loose from the bricks.
    Is there a silicone/adhesive/mastic I could use to re attach the arch that can withstand the heat and allow it move but not come loose?
    • 5259
    Inswool or Kaowool moudable caulk are high temp caulks (2000F) are a couple options.
