A few days ago, right after changing its 9v battery, my Zoto IR thermometer started reading way below the actual temperature. I know this, because I can point it at my woodstove, and it reads around 155 to 160 degrees Farenheidt. Point it at cooler things and the temperature does go down from there, but I haven't checked to see if there are temperatures at which it is accurate. There's nothing at all wrong with the display, but it is just obviously giving me the wrong temperature (by a lot). Has anyone else had this experience or have any suggestions for fixing it?
Thanks.
Thanks.
