Subject: Tips for tiling a Primavera 70 dome?
  • Fonsecac23
    • Oct 2026
    • 1
    I'm planning to tile my Primavera 70 with 2" x 2" porcelain tiles on 12" x 12" mesh sheets. Any tips or techniques for handling the curvature while keeping the grout/grid lines reasonably aligned?
    Should I use full sheets where possible or cut them into smaller sections as I work up the dome? Any lessons learned, especially around the tighter curves, arch and chimney, would be appreciated.
    • 9208
    Probably the best way would be to cut the tile sheets into strips and start glueing them in rows, starting from the bottom.
