Re: Pizza Oven on a Trailer
The Pivot Stove Company uses this idea. When I started my WFO they had a unit listed on their website:
Pivot Stove & Heating Company
Their unit was exactly what you are suggesting: two shells, one inside the other and the interstitial space filled with sand. They didn't, however have any insulation over the outside shell!
If one were to go this route I would suggest finding a local foundry and do them a favor by taking their spent casting sand. It is only good for so many trips thru the cope and drag and then it needs cleaning and refortifying with new binder. This is usually not worth the effort or expense and they dump the sand buying new. The sand is quality refractory sand and is one gets lucky one could even find olivine sand (green sand) which is very heat resistant and would be an ideal choice.
Wiley
Wiley
