Re: Harbor Freight 10" Tile Saw
Grats Skool on your purchase. I am pretty sure your gonna like it!
Travis
Travis
 The QEP had a 2 hp motor versus the 2.5 advertised by HF.  The biggest obvious difference is that HF has a much beefier and adjustable support for the motor/blade unit, which I suspect would contribute to smoother cuts.
  The QEP had a 2 hp motor versus the 2.5 advertised by HF.  The biggest obvious difference is that HF has a much beefier and adjustable support for the motor/blade unit, which I suspect would contribute to smoother cuts. ; but I think you'll find it is more than capable of doing even tricky cuts for your oven.
