Does anyone have any experience in using a gas burner to accelerate/better control start-up times on a wood fired oven?
Accelerate Start up with a Gas burner?
Re: Accelerate Start up with a Gas burner?
For firing the oven, for cooking, gas isn't recommended. If it's an external burner, with a tank that can be stored away from the oven, it would only be slow and expensive. If the burner and gas line is built in, it could be a disaster, because of accumulation of gas in the dome.
You'll be surprised at how fast wood will get your oven up to speed. You can crank out some serious BTU's with wood.Ken H. - Kentucky
42" Pompeii
Actually, these weed burner type wands work very well to kick start a fire....it's roaring almost instantaneously. CJ uses one in his barrel oven and after seeing his I got one for a Fathers day present.Originally posted by dmun View PostIf it's an external burner, with a tank that can be stored away from the oven, it would only be slow and expensive.sigpicTiempo para guzarlos.....
...enjoy every sandwich!
I use a gas burner for curing the oven because the temp rise is very gentle and constant, unlike wood which is harder to control. I put the burner on for 24 hrs and the temp rises gently to about 250 C in 24 hrs. Then jump to a few bigger curing fires with wood to finish off.Kindled with zeal and fired with passion.
If you really want to get some serious heat fast into your oven, then use a small hair dryer for some forced air induction. But it's really better to just give the structure time to absorb heat from the wood as it will do in its own good time.Kindled with zeal and fired with passion.
