vermiculate vs cement
  • its all in the base
    • Sep 2008
    • 11
    Hi all, my son and i just dug about a inch of vermiculate out of the top slab. It had been a week and still soft. I guess i want a form base to work on. I am now thinking of just using concrete blend and mixxing some vermiculate in with it.
    I am going to lay anther layer of chicken wire down then my mix of 50 concrete blend to about 40 of the vermiculate and a good amount of cement.
    Will this be ok my oven will only be used now and again just to cook a couple of pizzas or a roast.
    Thanks for any feed back
    P.S i am worried about the slab cracking if it does can it just be filled in so it does not look to bad
    cheers all
    Re: vermiculate vs cement
    The mix you are planning seems entirely wrong. It won't have any strength and it won't have much insulating value. Or maybe I'm misunderstanding you, maybe with some more explanation and a picture or two we could help more.
    I've gone back and read your two previous posts, and I still don't understand. Please explain to us:
    Did you start with a support slab? Is it reinforced? How thick is it? What concrete mix did you use for it?
    Your vermiculite concrete layer: How thick is it? What proportions did you use to make it? How did you mix it? Did you use vermiculite from the garden supply, or silicone treated stuff made for domestic insulation?
    Again, when we know more, we can help more.
    • Rastys
      • Feb 2009
      • 118
      Hi
      I have looked back through your posts and not much detail on what or how you did it.
      The type of vermiculite, your mixing ratio and method of mixing is critical to the insulation layer success.
      I followed Nissanneill's build and it worked out very well. He has his oven build at
      and see the second posting which he explains well the vermiculite material, mixing and included pictures.
      He has since given the forum away but his advice and help still remains.
      Rastys
      If you don't succeed the first time, try again and again until you get it right!
      • SpringJim
        • Apr 2008
        • 562
        BTW, I used the silicone treated stuff and was able to get a very nice product for use under the hearth and over the dome. Low ratio of cement to vermiculite and the finished product floated. I still need to stucco the outside but the material seems to be holding up well after a year.
        Jim
        Yeah, it was tough to mix but I used the water cement slurry method with good success
          This is good to know, I'm only repeating what I heard about the silicone treated stuff. One of the reasons this forum is so valuable is that people share their experience with different products and processes.
            • Sep 2008
            • 11
            Well thanks for that guys, i will hold off and not do it after work today i will re read your replies and the attachments. At least I don't have to rush home and start up the mixxer.
            the vermiculate i got was from a garden supply shop hope this is the right stuff cheers
            P.s hope you all had good nights sleep I am off to work now cheers all
              Yep, you got the right vermiculite.
                • Sep 2008
                • 11
                Thanks dmun and all others
                Yes 3.5 inch support slab with steel in it
                vermiculate 4 inch
                cement with 1-3 mix
                mixxer and in a barrow
                yes garden supply vermiculate
                  From the plans:
                  Prepare the insulating concrete using a ratio of 5 parts vermiculite to 1 part Portland cement (5:1). Mix the vermiculite and Portland cement, then add water and mix until you reach an oatmeal consistency.
                  Five to one is the largest ratio I've heard used, other makers have gone to 7:1 by pre-mixing the portland and water with a power paint mixer. Your three to one ratio may simply not have enough aggregate to do the job.
                  And make sure you are using portland cement, not one of the mortar or concrete mixes.
                  • Neil2
                    • Oct 2006
                    • 1374
                    You don't need the chicken wire.
                      • Sep 2008
                      • 11
                      Hi all, I am a happy chappy at the moment just took my form work off and all seems ok, so thanks for all your help it was great. I have never done anything like this before so its just so cool to stand back and view what has just been done. I was chuffed as even after getting my form work up so thanks again.
                      P.S One thing i will say to others that are going to be doing this is i used a trowl and tapped on the top of the slab to get the cement up a couple of times say after 1 hour and again 1-2 after that. I think that was what i did not do enough of. Also if you are not happy with the way the vermiculate has gone off it is very easy to scape it up and do it again till u get it wright so thanks again
                      cheers all
                      • Neil2
                        • Oct 2006
                        • 1374
                        "tapped on the top of the slab to get the cement up a couple of times say after 1 hour and again 1-2 after that."
                        Don't do that.
