Last night we had very heavy rain showers over the south of England. This morning I noticed that the firebricks on the outside arch and chimney were very dark because they soaked up a lot of water.
My question is whether it is worth protecting the bricks? B&Q sells a product with the following description:
"B&Q Brick and Masonry Sealer is a water repellent that penetrates the surface of dry porous brick, stonework and concrete. Once applied it forms a protective barrier which helps prevent damage from the ingress of water and damp whilst allowing the surface to breathe and let moisture vapour escape."
I guess that one issue with using a product like this is that the chimney is getting very hot.
Any advice or thoughts would be much appreciated.
