I really liked the idea of building arches and a dome, so I decided to make an arched vent, like in the FB plans.
One great thing about my keystone, was that it provided a level surface to set my flue section upon.
The only problem is, the flared opening of the arch/vent flares 'up', not down.
The opening at the bottom of the archvent is 56 sq. in. If I use just one brick, cut at the proper angle and mortared in, I bring this down to a 44 sq. in. opening at the top.
Above that is the flue section, which , in my case has about a 70 sq.in. cross sectional area.
Thoughts? Would it be worth it to go to an 8x8" section ( which, depending on the actual size) might step it down to around 40 sq. inches for the top 2 feet.
I am still building up the bricks for the flue section.
I will be lighting a few preliminary curing fires with this in place just to get a feel for how the flow of smoke will actually go.
[ I am editing this post so no one might see and think it acceptible --- after building this, the smoke collection area is too small. I will eventually chisel out the bottom on either side to give the smoke more area to go up... all across the landing area]
