Here's how I plan to lightly tamp on the vermiculite portland layer and also shape a spherical dome.
I wanted to make a curved makeshift trowel. Just a piece of masonite, tileboard, or sheet metal, of the proper length, tacked on to a 2x4 handle. Since my oven is 39" inside diam,the extra 9" of fire brick gets you to 4 feet diameter for the dome, and add 6" all around and the diameter is 5', so , a 30" radius on the trowel arc.
The first notion involved some angled boards and some biscuits, perhaps, but then I decided to REALLY make it easy ( and MUCH stronger and functional) but just clipping off the ends of a 2x4 at 30 degrees, then attaching them below!
( see the drawing)
On the sides I am using metal lath. After scratch coat, I should be able to fill with the vermiculite/portland out to 6" or so. Then on top, I am going to use blanket under and tamp the vermiculite on with this arched tool ( hopefully) What's cool about a curved trowel is, it really should start to define a sphere much the same as a flat trowel defines a plane.
I'll post the outcome.
( see the drawing)
