Insulating the oven entry
  • blacknoir
    • Jun 2009
    • 243
    How far out past the oven opening do you really need to have insulation? I'm talking both the board under the bricks and the blanket and/or vermi around the walls.. I'm curious what others did. I plan on checking the temp of the outside of my bricks once I start cooking to see just how hot it gets and how far out it extends to see if I really need all that much insulation.
    If I can pull it back a bit it would be nice for the floor to help prevent water damage.
    -Shay
    Shay - Centerville, MN
    My Outdoor Kitchen/Pompeii WFO Build...
    Re: Insulating the oven entry
    The bricks in the entry get REALLY hot. Even the decorative stone arch in front of the firebrick structure gets hot. I insulated out to the mouth of the firebrick entry: I don't know how much heat loss there actually be if you didn't.
    • Jed
      • Apr 2008
      • 428
      In contrast to Dmun's, I did not insulate the entry.
      The oven works fine but I certainly do loose heat through this path. I might get longer bakes if I had insulated this area.
      JED
