Refractory Mortar Poll
  • Refractory Mortar Poll
    Simple question, what form of refractory mortar did you use, and why? Feel free to offer your experience after-the-fact, especially with regard to price, ease-of-use, and effectiveness.
    [] Non-Calcium Aluminate Homebrew
    [] Calcium Aluminate Homebrew
    [] Heatstop 50
    [] RefMix
    [] Other
    Brief reason: ?
    Cheers!
    71
    29.58%
    21
    5.63%
    4
    Heatstop 50
    29.58%
    21
    RefMix
    14.08%
    10
    Other
    21.13%
    15
    Re: Refractory Mortar Poll
    Rats, in retrospect, I realize that a very useful distinction in the poll would have been between 'Other Homebrew' and 'Other Premixed'. Please specify in a comment.
    Thanks.
      I used heatstop 50, because I'd used it before on a fireplace liner. It's really easy to use, and forms a strong bond. It mixes easily, and spreads like creamy peanut butter.
        @dmun, I have access to HeatStop 50 here. It's $70-$80 a bag! I was planning on using it except that I started wondering about other options.
        Let me ask you this, I'm making a 36" oven. Can I do it with one bag? (Let's see, the directions suggest 130-180 lbs. Is that dry weight, as in 3-4 bags of HeatStop?)
        Are RefMix and HeatStop are volumetrically equivalent? Do two 22 lb RefMix bags mix about the same amount of mortar as one HeatStop 50 bag, and as followup, mortar the same amount of overall construction?
          The poll may get a bit skewed. I used some Heatstop, Refmix, and home made. For the record, most was the home made.
          Les...
            Ah, I didn't realize there might be a lot of mixing. I'm just trying to figure out the best option. HeatStop is expensive (RefMix is virtually the same price). Maybe I'll just homebrew it...if I can fine the parts and be confident that I can mix it such that it actually works properly.
            Coming into this project I can safely say I knew next to nothing about cement, concrete, mortar, etc. It's just completely unknown to me, but I'm looking for cost-cutters and the pre-mixed mortar seems very expensive.
            Thanks.
              It is expensive. I burned through the first bag of heatstop in a heartbeat. That is why I went to the home mix and it seems to work pretty well. I borrowed some refmix to attach my flue from Acoma. If you are going to buy the good stuff, buy Refmix - thats what James sells
              Les...
                The advantage of HeatStop over RefMix, in my case, is that I can get it without shipping and it's sold at the same place that I can get the firebricks for the lowest price around (so I'll be going there anyway). Since they're cost is nearly identical (I haven't even factored in shipping yet, which makes RefMix more expensive), I was leaning toward HeatStop...
                ...but *now* I'm leaning toward homebrew. ;-) Assuming it really does the job it needs to do.
                Cheers!
                  I used Sairbond. It spread easily and was very sticky. it is an air dry refractory mortar that was only $35/ 55lb bag.
                  I DO NOT RECOMMEND IT! Unless perhaps you are going to precisely cut everything and keep all your joints down to 1/8".
                  I suffer from myriad shrinkage cracks!
                  I wish I had tried the Refmix or the calcium aluminate home brew or the regular home brew, ANYTHING but Sairbond
                    I used Heatstop 50. My 77 cent a piece firebrick supplier had it for $54 a bag, I bought 3 bags and used 2 on a 36" dome that was cut to fit (no gaps over 1/4"), but I did cover the entire dome with a 1/2" layer on the outside(that took up the entire second bag, otherwise I would have only needed 1 bag.
                    I really only had the heatstop and one of the wet mortars in a bucket to choose from at a local refractory supply. I had read many reports to stay away from the wet stuff in and oven build, I had also heard that the hombrew with lime can be a bit difficult to work if you don't get the amounts exactly right.....that sent me to the heatstop.
                    Heat stop is really easy to work, smooth and creamy like peanut butter and it has a great sticky ness when you get the water amount just right. My only complaint is the 4 time reoccuring arch crack. Even though it is a high heat area I am going to try type N this time...certainly won't make the crack any worse.
                    RT
                      Thanks to everyone who is contributing to this poll and discussion. For those of us starting out (well for me, I can't speak for anyone else) these expositions are quite informative.
                        I used a mixture of refactory clay and refactory sand - no cement component at all. The whys and wherefores are in this thread:
                        http://www.fornobravo.com/forum/f8/h...clay-2783.html
                        I think some other forum members have used this kind of mortar since (dvonk for one).... and it still seems to be working fine after nearly two years of use. Of course the intresting question would be what its like after 20 years or 100.
                        I'll be sure to let you know when we get there
                          Heat-stop is expensive, and it's not immune to cracking. I used less than one bag for my dome, but my dome is thin, and cut-to-fit, an approach I don't necessarily recommend. I spent more in diamond blades than I did on heat-stop.
                            I used a product called Super 3000 Dry mix. I blended it 1:1 with sharp sand from our creek. It worked out well, there's a few cracks but that's to be expected, and I can't complain seeing as I have not woken up to a pile of rubble where the oven used to be. This oven has produced over 500 bread loafs and countless pizzas in the last 2 1/2 months. I am very happy....
                            Ian
                              my heat stop was $ 67.00 a bag with tax. I used about 3 1/2 bags. As i said before in other posts, Much of my use was loss and dropping due to inexperience, Only mix a little at a time,, Be as careful as you can,, keep your joints as tight as you can,, i have a 42" interior dome, Im sure i could have done it in 3 bags, maybe 2 if i was really carefull... Now I know better for when I build my next oven (haha)
                              Mark
