Hi all I am midway through constructing a 42" tuscan style dome oven with reclaimed firebrick in Hawaii. My family has a warehouse and had some thermocouples laying around that I thought I might be able to use. However they are not a thin wire, but more like 1/2" dia of stainless steel, and about 8in long connected to a thermometer at the end that goes up to 1000 deg F. Would this work if I planted them in the mortar in the dome or would cracking be an issue due to expansion of the metal? Thanks in advance for the help! This is a great website and I hope to be posting some pics soon!
aloha,
Karl
aloha,
Karl
. The thermocouple in the hearth was routed through a pipe that I cast into the reinforced concrete hearth slab, then through a hole drilled in the insulation board, and then into a hole drilled halfway through a hearth brick. So you probably don't want to start messing with that, and I'm not sure how you'd read that dial without climbing under the oven.
