When "floating" the foundation and/or hearth after screeding it with a 2x4, do I need to use a metal float or is a piece of wood with a handle on it sufficient? Does it make any difference structurally (does one draw water to the surface more or less than the other, and is that a good or bad thing?) or is it purely aesthetic with regard to the appearance and texture of the concrete (in which case I'll probably just go with the wood since I don't care what the concrete looks like, I'll probably flagstone it later anyway.).
Thoughts?
Thoughts?
