I've never seen any suggestion of using insulating firebricks for the hearth insulation, only various "boards" (superisol) and aerated concretes (vermiculite & perlite). Perhaps I'm misunderstanding something, but isn't this exactly what insulating firebricks are designed for?
What am I missing here? Are they really expensive or not very insulative or difficult to work with? I'm sure there's a perfectly good reason for why they aren't recommended, much less barely discussed, but I'm not aware of what that reason is yet.
Final thought: even if they shouldn't be used for the entire floor, would they make good standoffs or "columns" embedded into the vermcrete/perlcrete at, say 12"-18" spacing (half bricks perhaps) to provide compression resistance to the weaker concrete?
...of course that idea is only necessary if compression is a serious issue in the first place and I get a very strong impression from this forum that compression is virtually never a problem, even at 7:1, but would they help in such a case?
Just brainstorming.
Thanks.
Just brainstorming.
Thanks.
