I believe (I don't have it in front of me right now) that the Pompeii directions suggest a 1:5 ratio (portland to vermiculite/perlite of course). On the forum I know I have read mention of some other ratios, at least at divergent from Pompeii as 1:7. I don't recall specifically.
What is your recommended ratio and why?
Followup: Do you believe the ratio should be varied with vermiculite/perlite "grade", which refers to the size of the grains? That is, would larger or smaller grains require an alteration to the cement ratio?
Standard grades, as I understand it, are in four steps (generally labeled 1 to 4, 1 being the smaller grains), the smallest being sand-sized, the largest being dime-sized, the two intermediate sizes being, I dunno, BBs and half-dimes respectively, I suppose. What "grade" did you use and what are your thoughts on it?
