Hello all,
My wife is visiting the US next month so its my chance to get her to pick up some stuff from the US as our exchange rate is fairly good at the moment.
Is there anyone that can recommend thermocoupler manufacturers for the pizza oven so I can measure temps in atleast the dome and hearth also any recommendations on Digital or analog temp gauges would be great.
Now my 2nd question is a little wierd I guess and not to sure if I really will need to do this as the whole concept of the dome is even cooking through out the dome. I have mentioned on a few posts that I will be doing tandoori chicken, tandoori lamb, roasting turkeys fo thanks giving and xmas for my wife when she is here
. I was thinking of putting at the back of the pizza oven a stack of bricks with the 2nd or third course maybe having 3 holes drilled into it and when I am doing tandoori chicken or a roast putting them on skewers and having a brick setup that can be removed when not used at the fron of the oven that will raise the meat off the floor and cook while suspended. Now my question is does anyone know of any bearings that can maybe be added to the back of the oven inserted into the bricks so I can add a motor to the outside to maybe rotate the meat to cook evenly.
Any ideas would be greatly appreciated.
ikhan42
. I was thinking of putting at the back of the pizza oven a stack of bricks with the 2nd or third course maybe having 3 holes drilled into it and when I am doing tandoori chicken or a roast putting them on skewers and having a brick setup that can be removed when not used at the fron of the oven that will raise the meat off the floor and cook while suspended. Now my question is does anyone know of any bearings that can maybe be added to the back of the oven inserted into the bricks so I can add a motor to the outside to maybe rotate the meat to cook evenly. Any ideas would be greatly appreciated.
ikhan42
