Is it possible to use a miter saw with a diamond blade to cut bricks? I got one used for $25, so even if the dust ruins it, it's not a big deal.
Miter saw to cut bricks?
Tags: None
Re: Miter saw to cut bricks?
Hi Jim,
sure they are, just use a diamond blade (as they cut quicker, smoother and I believe with a little less dust than a friction disc) but I would squirt the dust out into a plastic box/bag that has a fine garden water spray to settle the dust. You can have a spray directly onto the blade but be careful that a mitre or even I would prefer a 14" steel cut-off saw are not designed or anywhere near water proof or resistant and a potential source for electrocution.
Diamond blades are readily available on ebay for rediculously low prices at times so keep an eye out for that bargain, around $20-25 for a 14" blade.
NeillPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
I would have really liked a compound miter, wet saw. For $25 I would try the miter saw, soaking the bricks to keep the dust down, but be careful with water, since your saw is not intended for use around water.Joe
