Re: Tips for Mobile frame for Pompeii Oven
Hey and Whoa!
First of all - I'm not going to drive with my oven on the highway. I just want to be able to move it around the yard/house as needed.
Second - the frame is going to be 5X5 ft. with 9 or more legs that every leg is going to get a wheel so all the pressure goes to the ground directly (nothing is holding).
Third - I am working in construction. My specialty is heavy duty concrete jobs. And where I come from (Israel) we build the house from concrete and we use the wood to put the concrete onto. This is tons of pressure that is put onto the wood which is only 1x4". so doubled 2x4 will be much stronger.
Fourth - regarding the insulation from the wood frame - it's going to be a layer of 1-2 inches of salt (insulates very well) on top of that there are going to be 2-3 inches of concrete and then I am going to build the oven.
Fifth - I'm not going to do a house shape for the outside, I am going to keep the igloo shape so that means only 6-8 inches of insulation.
Thank you very much. I've been enjoying debating with you guys!
Have a good weekend!!!
Dvir
Hey and Whoa!
Dvir
