Re: How to attach hardibacker to a rebar skeleton
Given that actual design, this is how I would build it:
I would form and place the first layer up to the floor of tier one of vermicu-crete. I would then build the outer walls of the first tier out of cheap brick (called utility brick or commons). I would then form and place the second layer to the floor of the second tier out of vermicu-crete, with the outer walls of cheap brick. etc. I would then stucco (SBC) the entire thing, making sure to slope each tier to one low spot and weep it at that point. I would also cove all inside corners, and probably apply a coat of Thoroseal to the inside of the planters themself.
Fast and quick, and cheap and light to boot.
