I am attempting to design an insulated door. The interior face and 2" thick sides will be sheet metal enclosing a cavity (2" of course). The exterior face will either be metal or hardwood, I haven't decided yet. The cavity will contain 2" of InsBlock 19. Problem is, I don't weld. The sides will consist of tabs folded over from the inner face, then wrapped along the outer face. I might wrap a strip of metal around the edge over the tabs (riveted to each tab) but there will still be cracks and tiny holes at the corners and folds. I am not comfortable with exposing the InsBlock 19 to the oven interior in this fashion.
Thus the following proposal: What if I wrap the InsBlook 19 in foil before placing it in the door? I could either use ordinary kitchen foil (or the heavy version thereof) or perhaps some sort of flashing, any extremely thin metal would do of course. I have seen extremely thin copper flashing at HD for example.
Assuming enough "wraps" were laid around the InsBlock 19, do you believe this would adequately contain any outgasing or vaporization despite a lack of a true sealed compartment?
Additionally, would wrapping the insulation board in foil defeat the purpose of the insulation by letting all the heat transmit around the edges through the foil? I figure, if that were a real problem, then the heat would already be transmitting around the edges of the exterior sheet metal anyway, so this shouldn't be a problem (not any more so than it already is at any rate), but I just don't know. Since lots of doors have an inner metal face that wraps into metal edges and then right to the exterior of the door, it seems like heat loss through the metal comprising the door isn't generally a serious problem.
What do you think?
What do you think?
