Yeast Quantity
  • Dutchoven
    Re: Yeast Quantity
    This is a really great thread...my only addition to this comes in...what are the other variables in each members formula. Keep in mind that if you use 10 gr yeast to 500 gr flour it is only a 2% addition in the formula...which in many cases is exactly what is used for most bread. IMHO if you are doing an overnight or longer refridgerated proof using commercial yeast you could cut that in half. The amount of yeast could be reduced nearly to nothing if the purpose were to create a longer fermentation time...3 gr to 1000 grams is minimal and 4 hours to double is acting more like a sourdough...no disrespect Dmun...I think it must give you a very interesting flavor that you could almost say would be truly your own. 10 gr per 1000 seems to make good sense to me.
    Best
    Dutch
  • dmun
    Re: Yeast Quantity
    Originally posted by RTflorida View Post
    Most of my pizza time is Sat or Sun, with a lot of traveling during the week. At best I usually only get to make dough the night before. I've tried freezing the originally posted dough recipe, I've found it to be pretty good for about 2 weeks in the freezer. Can this recipe be frozen with good results?
    I've frozen the dough and it seems to work fine. The tricky thing is getting it the right temperature when you defrost it. If it sits out on the counter all day it's way too warm and stretchy. Look for holes and wierd shaped skins. I'm sure that you can figure out how long to defrost successfully.
    or better yet, can the 3 days be cut back to 1 or 2?
    I've done two days and four days with success. The idea of the two waiting periods, the twenty minutes between stirring and kneeding (which is called the autolise) and the three days in the fridge (which is called cold retardation) is to develop the gluten structure that is ordinairly produced mechanically, by kneeding or mixing. I think there is lots of room for experiment, but this is what is working for me at the moment.
  • dalucca2003
    Re: Yeast Quantity
    Originally posted by james View Post
    James,
    Should it be 1.5 gr. with 500 gr of flour. It looks like Dmun is adding 3 gr. with 1000 gr. of flour which seems to make more sense.
  • RTflorida
    Re: Yeast Quantity
    Sounds like it is worth a try, I really like the idea of little kneeding. (I need a new mixer for one thing and am also recovering from shoulder surgery - with the other scheduled for next month).
    My question, what if you don't have the luxury of making the dough 3 days in advance? Most of my pizza time is Sat or Sun, with a lot of traveling during the week. At best I usually only get to make dough the night before. I've tried freezing the originally posted dough recipe, I've found it to be pretty good for about 2 weeks in the freezer.
    Can this recipe be frozen with good results? or better yet, can the 3 days be cut back to 1 or 2?
    RT
  • james
    Re: Yeast Quantity
    Here is the updated HTML page:
  • dmun
    Re: Yeast Quantity
    That's it exactly:
    1000 caputo flour
    3 grams IDY
    20 grams table salt
    mix dry ingredents in large bowl,
    add 630g water,
    Mix with silicone spatula until just combined. Let sit 20 minutes.
    Kneed on lightly floured surface 10 or 12 folds, form into ball, the dough will be sticky, try not to use more flour than you have to. Keep the silicone spatula close to hand if it starts sticking to anything.
    Put back into bowl, cover ball with no-stick sprayed cling wrap, put into warm place for about 4 hours.
    Use your silicone spatula to tilt the dough out onto the counter, flatten gently, divide into 8 wedges with dough thing:
    Check for ~200 gram dough weight, form into small balls, put in rubbermaid storage containers with hole poked in lid, refrigerate three days.
    The pizza dough handles best when it's about an hour out of the fridge, still cool to the touch but not cold.
    What's news here is cold storage does the same job as long kneeding or expensive mixers. This insight is from the no-kneed bread experience.
  • james
    Re: Yeast Quantity
    I have to agree.
    Time to update this. We have the web page and the .PDF. What is the consensus on how much IDY (not fast or active) should we recommend? I am thinking 3 gr to 1000 gr of flour should do it.
    What do you think?
    Also, are folks happy with David's 20gr of salt per 1000 gr of flour?
  • dalucca2003
    Re: Yeast Quantity
    Dmun....on that recipe for 1000 grams, what are your other measurements? I am assuming 600 - 650 gr. of water and 15 - 20 gr. of salt besides the 3 gr. of instant yeast.
  • dmun
    Re: Yeast Quantity
    I use instant yeast, not active, and I use a LOT less than that. I use 3 grams of yeast for 1000 grams of flour. (20g salt 630g water) This doubles in bulk in a warm place in about four hours, then I divide into 8 balls and cold retard in the fridge for three days (or two, or four) When I used more, it blew up way too fast, and had a disagreeable alcohol smell.
  • asudavew
    Re: Yeast Quantity
    Do you like your results?
    If you are happy with the end product then I think it's perfect for you!
    Less yeast would probably slow rise times, but it might improve flavor some.
    What the heck, you may want to give it a try!
    Hopefully Jim will weigh in soon. This is more of his dept.
  • dalucca2003
    started a topic Yeast Quantity
    Yeast Quantity
    I have a question in regards to yeast quantity. The VPN dough recipe provided by Forno Bravo calls for 500 gr. of flour, 10 gr. of salt, 650 gr. of water and 10 gr. of ADY. My Bosch mixer can easily handle greater quantities, so I usually triple my batches. I spoke with a very informed gentlemen who stated that 30 gr. of yeast seems a bit too much.
    What are others doing when they are making double or triple batches of dough? The gentlemen said everything else looked good except the yeast. He further stated he would probably use 30gr. of live yeast but you need to use less if you are using ADY. Any thoughts?
