Dough - Forno Bravo Forum: The Wood-Fired Oven Community
Dough
  • Dough
    I am new to pizza making and am confused about kneading the dough. I was introduced to stone pizza making when watching a pizza episode on Alton Browns Good Eats. I have made about 50 pizzas using his method and am pleased with the results. Alton has me kneading the the dough for 15 minutes using a dough hook in my kitchen mixer to develop the gluten. The Forno Bravo method in the ebook cautions overworking the dough and involves much less kneading time. I plan on trying the FB method but I would appreciate it of someone could explain the differences in these two approaches. Thanks in advance!
    Re: Dough
    Alton Brown is an excellent master to follow. I remember being new to dough and going through the same questions that you are having. The first thing that I would recommend is to put the Kitchenaid aside. If you really want to learn this art, knead by hand. You will never overmix that way. Here is the recipe that I use:
    PIZZA DOUGH
    This dough is based on one from Chris Bianco, chef of Pizzeria Bianco, that ran in our October 1999 issue. It is an accompaniment for Eggplant, Tomato, and Fontina Pizza.
    1 (1/4-oz) package active dry yeast (2 1/4 teaspoons)
    2 1/4 to 2 3/4 cups unbleached all-purpose flour plus additional for kneading and dredging
    1 cup warm water (105 - 115?F)
    1 teaspoon salt
    Make dough:
    Whisk together yeast, 1 tablespoon flour, and 1/4 cup warm water in a measuring cup and let stand until mixture develops a creamy foam, about 10 minutes. (If mixture doesn't foam, discard and start over with new yeast.)
    Stir together salt and 1 1/2 cups (7.5 oz) flour in a large bowl. Add yeast mixture and remaining 3/4 cup warm water and stir until smooth, then stir in another 1/2 cup (2.5 oz) flour. If dough sticks to your fingers, stir in just enough flour (up to 3/4 cup), a little at a time, to make dough just come away from side of bowl. (This dough may be wetter than other pizza doughs you have made.)
    Knead dough on a lightly floured surface with floured hands, lightly reflouring work surface and your hands when dough becomes too sticky, until dough is smooth, soft, and elastic, about 10 minutes. Divide dough in half and form into 2 balls, then generously dust balls all over with flour and put each in a medium bowl. Cover bowls with plastic wrap and let dough rise in a warm, draft-free place until doubled in bulk, 1 to 1 1/4 hours.
    Cooks' note:
    Dough can be allowed to rise slowly, covered, in the refrigerator for 1 day. Bring to room temperature before using.
    Makes 2 (10-inch) pizzas.
    When the dough first comes out of the bowl, it is very loose with dry and wet ingredients visible. Set the kitchen timer for 10 minutes and start kneading away. By the 10 minute mark, all the dry ingredients will be incorporated in the dough ball and you should have a pretty homogeneous dough. At this point, cover the dough with a damp clothe. Let the dough rest for about 15 minutes. While the dough rests, gluten will be developing. After the 15 minutes, knead the dough for another 5 to 10 minutes. The full proof test to ensure that the dough is properly developed is the "window pane" test. Pull a small piece of dough away from your ball. Flatten the dough out between your hands. Then stretch the dough slowly. If the dough is ready, you will be able to stretch it thin enough that you can see light through the dough. If the window pane tears, then you know more kneading is necessary.
      Re: Dough
      1 teaspoon salt
      Wow, that's a lot of yeast.
      The suggestion to kneed by hand is a good one. An even better one is to realize that with a day or two of cold retardation, your gluten will develop all by it's self. I stir together my ingredients, let rest for twenty minutes, hand kneed for just a minute or so, then bulk rise, divide, ball, into containers, and pop them in the fridge. After a day or three, the dough is as smooth and stretchable as you could want.
        Re: Dough
        That is almost exactly twice as much yeast as I use.
          Re: Dough
          i have a big group coming over for New Years Eve. i plan on making the dough the night before, let it rise, divide, ball, and cover.. put it in the cold garage. the question i have is, when should i bring it in the house to room temp prior to making pizzas?
            Re: Dough
            Most let it go to room temp, but I use it straight from the fridge.
              Re: Dough
              Thanks. by the way, tusr18a, you mention "our October 1999 issue"..which publication are you associated with?
                Re: Dough
                Stoneylake, wish I could say that I was associated w/a publication. The real story is that I copy/pasted the recipe from another source. I think it came from Gourmet Magazine. That dough recipe has never failed me. Gets rave reviews everywhere I go. I would make sure that you give yourself enough time for the dough to come to room temperature. The dough should double in size.
                  Re: Dough
                  Thanks all for the advice. I have tried the FB recipe/method and it turned out OK. I think I need to experiment further as my dough was a bit sticky. Apparently the dough should be sticky but I think I was a bit too sticky.
                    Re: Dough
                    has anyone tried going lower with the % water on the forno recipe....I mean down to like 55 56 or 57 %
                    If so what did you think...I am making a batch right now with 57 % but I do not intend to cook it...just mix it to get the feel,
                      Re: Dough
                      Something sounds a bit strange if you are finding you must go to 57 % hydration to get dough you can handle. What kind of flour are you using and what recipe - there are several on FB? And how are you mixing? I don't know of any AP flours that can't be manageable at 60%.
                        Re: Dough
                        OO flour...500 gram 325 gram 7 g salt 3 gram yeast
                        i just want to see what happens if i lower moisterue so i can lower oven temp to see what happens
                        mix till wet....wait 30 minutes....kneed with mixer for 8 minutes...cold ferment.....ball before use and rise at room temp for 90 minutes
                          Re: Dough
                          Hi All,
                          Non-expert baker here, but I want to share some information I read in an artisan bread book about no-knead bread dough. Dough will form gluten if it is "wet" and allowed to ferment for several hours or overnight, no kneading at all. The method works well if you make up the dough in the morning and either cook with it that evening or put it in the 'fridge and bake the next day. I've tried other methods and they all seem to work but this no-knead method produces the best results for me. Some folks either don't like the method or haven't had good results, but my breads and pizza doughs are a vast improvement over previous methods that I've tried.
                          To give you some idea of the method view this YouTube video: YouTube - Making No-Knead Bread
                          and a recipe here: No-Knead Pizza Dough Recipe by Jim Lahey from Co. Pizzeria in Chelsea, New York City | New York City - TastingTable
                          Try it. It takes the issue of too little or too much kneading out of the equation. A caveat though, don't be tempted to over mix or knead this dough, it just isn't necessary.
                          Cheers,
                          Bob
                            Re: Dough
                            Hi Bigred!
                            As you go to lower hydrations you will tend to get smaller bubbles and less spring in your cornicione. It can be beneficial if you want to make thick pies with lots of toppings but it tends to run counter to what WFOs do best and most uniquely. If you use lower hydration and lower temp you will tend to get pies that are more like what you can make in your indoor oven at 500 F. With thin pies you will tend to overcook the dough and get tougher, chewier crumb and have a less charred and potentially less golden (if you cool too much) crust and less caramelization of the toppings. If you want to go that route you also lose a lot of the benefit of 00 flour IMO. To me it is at its best at higher hydrations and at lower ones you might as well use cheaper flour.
                            Good luck!
                            Jay
                              Re: Dough
                              i am looking to try 700 degrees and 57% with some extra sugar to get some additional quick browning. Looking for a little more forgiving temperature in the oven
