Re: Anyone ever made Weber Grill Pizza on a Stone?
TDVT....Looks like some pretty heavy artillery! Here's a picture of my LBE after I cut a side vent. Where do you live, the Yukon?
Villa Roma
LID PICS
Lid with stone mounted
Lid baffle
Well, the lastest version of the Pizza Weber is the most successful. MUCH more even cooking with a stone mounted in the lid. This contraption will get me through to better weather & some sort of proper oven. Still this is much better than cooking pizzas in our big range (commercial).
Initially, I had the firebrick splits (half-thick) on the wire rack which started to deform making the surface uneven, so I welded up a soild base for the bricks. Then I took the steel reflector plate the was mounted in the lid & mounted it higher in the lid so it was touching all the way around but cut out a section in the front (away from the stack) to allow gasses to escape. Then I welded some angle as spacers to hold the stone off the steel plate along with some little tabs to hold the stone in.
The theory this time is that the heat can reach both sides of the top stone & has to travel to the front, then towards the back to reach the stack. Hard to describe but easy to see in the pics.
It all seems to work. All the pies were cooked fairly evenly in about 5 minutes. No pictures of the pizza as we were busy eating them. Next time.
Before I ever saw this thread I had modded a small Weber with a stack (to create a draft, in theory) & added a steel plate suspended in the lid (to reflect heat on top of the pie, also in theory).
While I had some REALLY good pies, I found that the charcoal was VERY hard to regulate.
I was using cheap stones & had them on an aluminum plate, set on the actual grill. Often it would get too hot & the bottom would cook quickly but the top wasn't near done. I would have to put the pizza on a double-layer air bake sheet & continue until the top had caught up. The steel plate in the top DID help but not enough. I went through a couple of stones as well.
Then I saw Villa Roma's videos & modded the Weber again (same size as his) to rest on a turkey burner that we also already had. Much better but too much heat for a cheap stone so I made the switch to half-thick fire bricks.
Now, I think I'm closing in on a good set-up. The half bricks worked great though I still have uneven heating top to bottom. The next step is to add a baffle to the top & replace the steel reflector with a thin stone (probably the best use for those cheap ones).
Also have an IF thermometer on the way, so I'll try to put up some pics & info of the latest incarnation.Leave a comment:
Here's some pizza made on the little black egg (gas fired weber kettle). Both are 100% whole grain.
Villa Roma2 PhotosLeave a comment:
Please dont laugh at my first attempt at pizza dough making. These turned out really thick! Im still such a rookie in this department.
I have made pizza in my trusty old Weber. I used my wife's favorite Pampered Chef stone (I got real lucky and it didnt break). I set 2 firebricks on edge and placed the stone on top of them to get the pizza closer to the top of the dome. I mounted a thermometer in the top of the Weber dome and I got the temp up to about 500*.
I started the fire with Kingsford and added 2 splits of oak.
I did 2 pies on this cook and each took about 8-10 minutes.
Here's a football pizza made with the same 66% whole grain dough.
Villa Roma1 PhotoLeave a comment:
Here's a few pizzas I made this weekend. The first two are 66% whole grain and the second two are 100% whole grain. Cooked at 650 degrees for 3->3 1/2 minutes.
Villa Roma4 PhotosLeave a comment:
Hi James,
This batch of pizza was my first attempt at a Neapolitan style pizza. I only used flour, water, salt, starter and vit C. It puffed up much more than I had expected and had nice big air holes. I'll have to cut the amount of starter in half next time.
The recipe:
400 gm GM unbleached all purpose flour
400 gm GM Harvest King bread flour
528 gm cold water (66%)
1/2 cup rye starter
16 gm salt (2%)
pinch ascorbic acid (vitamin C)
For anyone that's interested, here's the link to a video of my first attempt at Neapolitan pizza using the LBE. I experimented with the temps at 690, 750 and 850 degrees. The video is in two parts, the first video is about 5 minutes and has an intro and the dough prep. The second video is about 3 minutes and is the cookoff of the pizzas. If for some reason the links don't work just do a search for "Little Black Egg Neapolitan" at YouTube.
YouTube - Little Black Egg cooks Neapolitan Pizza part 1
YouTube - Little Black Egg cooks Neapolitan Pizza part 2
Villa Roma2 PhotosLast edited by Villa Roma; 08-15-2007, 12:26 AM.Leave a comment:
Hey Villa,
I love the Sox pizza. Excellent.
I have a question on your corncione. I see that you are leaving the rim raised with your pizza base and leaving your sauce about 3/4" from the rim -- which really gives you a big and poofy cornicione. Are you getting nice air holes in the rim? I was wondering what would happen if you kept the corncione thinner (about the same as the rest of the pizza), and left it to poof up only by leaving the sauce away from it.
What do you think? Worth a try? Or, do you like the chunkier rim?
Inquiring minds...
JamesLeave a comment:
I just couldn't resist it. I had to make a baseball pizza! Maybe they'll start selling these at Fenway!
Go Red Sox......Villa Roma2 PhotosLeave a comment:
you are one amazing pizzaiolo.
Thanks for the pizza pep talk and the inspiration. I need to make some dough - with flour this time.
Wow BarbaraC, you've been gone for quite some time. We were about ready to put out an APB (All Pizza Bulletin) to help find you!
With all that work you've been doing, it sounds like you could use a much deserved break. What better way to unwind than to make pizza. There's something almost therapeutic about working the dough and making a pizza that's superior and healthier than anything you can buy.
You can even get creative when making pizza. For example, a while ago my brothers’ cat (Cracker Jack) vanished for several months. As you can imagine his daughters were devastated and almost all hope was lost but then Jack suddenly returned. To celebrate the occasion I made a pizza with a message. Check it out, it's 2/3 whole wheat!
Got baseball fans coming over for the big game? Imagine their delight when you surprise them with a baseball pizza? Cheese pizza with finely chopped red pepper to define the stitching and your teams emblem emblazoned in the middle. The possibilities are virtually endless. So much pizza, so little time!
Thanks and welcome back, Villa Roma2 PhotosLast edited by Villa Roma; 08-08-2007, 10:24 PM.Leave a comment:
so glad I asked the question... I have been away working myself to death dreaming of doing this and lo and behold the god of Weber Grill Pizza comes down to demo the most amusing and entertaining pizza making I have ever had the pleasure to witness, and so much more.
Villa Roma - you totally rock a Weber dude - thanks for your amazing diligence and incredible work. Amazing.
(Cheney never dreamed about your use for duct tape.)Leave a comment:
Villa,
Very well done indeed. Very clear, well shot and well explained. Thanks for taking the time and doing the work.
JimLeave a comment:
