Re: Help - Burnt pizza bottom!!
Hi Tenorio!
You seem to equate proper or underproofed dough with heavy pies. Methinks you are confused with the proper definition of overproofed. Heavy dough makes heavy pies and heavy bread. Properly proofed pizza (and most bread) doughs should not be heavy. They should be bouncy and light (at least somewhat) and feel alive - not like modeling clay.
Needing to go to 58 percent hydration is really strange. You must have really soft flour or some processing problems. As lwood indicated and I have long said, better to drop the hydration to where you can handle it and get your technique together than to have the dough so wet you are a basket case.
Back to overproofing... The simplest way to tell if you are overproofed is the color of the pie. If you scan some of the pie pics on this site you will see pies that have caramelized spots on the pie (cheese, and such) but the crust shows no color. That dough is overproofed. The yeast has consumed all the available sugar and multipled to the point that it is being starved by the rate of sugar creation by the enzymes. And no excess sugar means the crust doesn't brown. So you get a whitish, cardboardy dough or at least move in that direction. It can puff and it can taste okay but by day three or four it gets a bit strange.
Pizza is much more forgiving than bread. A little under/a little over, no big deal. There are also more variables than just time...
Good luck!
Jay
Hi Tenorio!
Good luck!
Jay
