Re: Flour or Cornmeal
I use flour and only use just a bit.
Cornmeal changes the flavor of the pizza.
The "trick" is to add flour to the dough on one board/marble then shake off the flour and transfer it to the peel - don't flatten the dough on the peel otherwise the dough will stick to the peel unless you put a lot of flour. You can get away with just a small amount of flour on the peel if you stretch it elsewhere.
Too much flour on the peel = too bitter taste of the pizza.
