Hi all, I am new to forums so please forgive me if my posts start off a bit simple.
I currently run a succesful mobile pizza business in Tasmania and looking at manufacturing our own domestic oven for Tasmania and maybe the mainland.
I am looking at getting feedback and suggestions on what others think of my design.
OK I have designed the oven and will get a fiberglass mould made for casting, I was thinking of an inside and outside mould bolted together for casting, I am thinking at this stage to use Shiracast 140? for the casting product with or without stainless pins?? I am not sure if the stainless pins are a good idea? The oven walls will be 70mm thick and the dome cast in two parts, the front entrance will be cast in one part and also a modular floor part for the entrance, (might be able to cast this with a lighter product as it wont be taking a lot of heat??), The floor of the oven will be 300x300x50mm firebrick with calcium silicate 20mm board under the firebricks?. I have designed the oven to be approx 800 wide x 920 deep, the entrance is 64% of the dome height?. I think I am on the right path and would welcome any suggestions, questions before I commit.
