40" Corner oven in Manor Lakes - West Melbourne
    • 5260
    #31
    Re: 40" Corner oven in Manor Lakes - West Melbourne
    Dan,
    Looks like you are still using full width bricks which are fine and long as you can make it work but probably will need to cut the width down as you go up and the radius of the dome gets smaller. You will know when you need to do this.
    • vanoontour
      • Jun 2012
      • 19
      #32
      Hey UtahBeehiver, the bricks are already cut in half? they are about 105mm on the faces you see looking from the inside.
      Dan,
        • 5260
        #33
        Dan,
        Think we are talking different dimensions, if your faces are 105mm roughly 4.1 inches on this side of the pond, you will probably need to cut the faces by 1/2 or 1/3s as you go up.
        • oasiscdm
          • Jan 2012
          • 1239
          #34
          Dan
          I would be trying half and half for the bond all the way through. If you look at mine I started too Cut the bricks to keep the bond. Towards the top they got to narrow so I crossed two bricks and then began to use grinder to shape the rear of the brick to maintain that brick to brick fit as the bricks get vertical
          If you want come over and check mine out before I plug it perhaps after work one night now daylight saving is with us. It's much easier to see in real life than to explain in writing.
          Cheers Colin
          Oven 1 Completed
          Oven 1 and surrounds
          • oasiscdm
            • Jan 2012
            • 1239
            #35
            Hi Dan Send a PM if you wish to come over. only night not good is Monday's
            Cheers Colin
            Oven 1 Completed
            • oasiscdm
              • Jan 2012
              • 1239
              #36
              Hey Dan. Did you get anything done on oven.
              Cheers Colin
              Oven 1 Completed
              • vanoontour
                • Jun 2012
                • 19
                #37
                Nah Mate, Uni got in the way...
