Wood fired oven corner build in Grafton NSW
  • Wayne73
    Re: Wood fired oven corner build in Grafton NSW
    Thanks Colin,Ive always look at his build when im unsure,dont know how i missed it.
    and yes Dave draw me a picture please
    Originally posted by Wayne73 View Post
    I could have a bit of a problem with the outer arch, I only have enough space left on the base for one brick length.
    Is this to short for an outer arch?
    Gudday
    No you have more ....just eyeballing one of you previous pics you can start your entrance outside the oven entrance. The insulation will be tight but what the heck there are heaps of ovens out there with no insulation gape to the entrance at all. That way you will get 1 and 1/2 brick to play with.
    Advantages I can see ....your chimney can be position directly over the oven entrance. The outer entrance will be then 1/2 brick larger than the oven entrance great for operating the oven definitly not cramped.
    Throw a 8 in chimney on that it will suck the Crome off a "56" Chevy.
    It you can't see this by the words I've written and I will make up a drawing to make it clearer
  • oasiscdm
    Hi Wayne
    I think Karangi used only one brick length with his landing. But he did have a decorative face from memory. Check out his build.
    I am planning the same one brick length landing but with a half brick decorative face same as house bricks I have had sitting there for 13 years. I have also found a stainless steel fabricator to fabricate a stainless face to the front of the oven landing should I decide not to go with the house brick face.
    What size is the Oven ? I am looking at 8" double skinned flue for a 1m internal oven. Doing similar to Utahbeehiver for his flue. Yes I know that poses a problem with a single brick landing being around 9" deep. But I will figure it out.
    You could flare the front landing which is what I am doing. That would give you some more options and a wider landing at the front.
  • Wayne73
  • Wayne73
    Thanks guys,
    does anyone know what size flue I need ?
  • oasiscdm
    Hi Wayne
    I'm jealous............. well done that looks so damn good.
  • Bacterium
    Wayne ...... At this point I felt pizza feels so close yet so far
    Nice work on final one.
    Gudday Wayne
    Wow that right out of the box!
    Well done though
  • Wayne73
    Now Im a bit stumped I hav'nt thought past the dome.
  • Wayne73
    Thanks Sharkey, I did think of doing a two piece key stone... and I did but horizontal.
    my two piece key stone.
    1st half in
    and the 2nd half.
    and the inside.
  • Sharkey
    Nice job Wayne
    Your last rows look almost exactly like mine. I used a 2 piece keystone - like this:
  • Wayne73
    Wayne,
    I know it's not easy and too late now, but there are quite a number of coinciding vertical joins of four courses of bricks. I hope they don't give you trouble. Hopefully ok because the dome is stronger in the top half.
    yeah I know fingers crossed
  • Wayne73
    Thanks I think I will be ok
    And now ready for the key stone but the hole is bigger then one brick, I will have to improvise.
    from the inside
    Gudday
    Camos build about pages 9 ..... They're are few that've posted a less than there perfect keystone ....... But there still gone on
  • Wayne73
    yep thats the idea ..though one brick on its end want fill the gap, Ill have to use two or three
