Bathurst Build 100cm ish - Forno Bravo Forum: The Wood-Fired Oven Community
  • Bathurst Build 100cm ish
    Hi All,
    Well I feel like I have officially begun now. I have the "approval" for the exempt development from council and my pile of bits and pieces is growing weekly. I have even staked out the site in the backyard.
    I have drawn up the template of the inner dome circumference and the brick layer and the insulation. I have sheets of corflute so I can make as may templates as I like yipee.
    Cheers,
    Rosemary
    My build so far
    http://www.fornobravo.com/forum/f51/...ish-19084.html
    Starting out collecting info and materials
    http://www.fornobravo.com/forum/f3/h...lia-18943.html
    Re: Bathurst Build 100cm ish
    Cut that short the little man woke up.
    So anyway we shall be starting in earnest this weekend digging out the area for the slab and putting in the form work. I gotta say the arch is doing my head in and I have not even started laying bricks yet.
    Heading to field furnace next week to check out their supplies. Can't wait.
    Colin you asked me on another thread if I was using hebel for the base. No I am not, at the moment I am tossin up between bessablock and the pretty version that will not need rendering or covering. I am still going with the hebel slabs for the top with lots of lintels underneath. I am going to create an album with all the photos but hav to swap to the big computer as the iPod does not let me load pics.
    Cheers,
    Rosemary
    My build so far
      Good luck Rosemary!
      I'll be watching your pictures and project with interest.
      Alex
      Fail to Prepare...Prepare to Fail!
        Looking forwards to the build.
        PS. cm is a dressmakers term, builders use mm.
          Been a while what with falling pregnant again. But hubby has some time off and things are moving on. Slab is down. Stand is up, cores filled. Lintels in place so it is really just up from here.
          I do have one question is it essential to have a double walled flue or can a single walled flue work just as well?
          Cheers,
          Rosemary
          My build so far
            been meaning to post some pics here they are
            Cheers,
            Rosemary
            My build so far
              and some more
              Cheers,
              Rosemary
              My build so far
                and more photos
                Cheers,
                Rosemary
                My build so far
                  and yet more photos
                  Cheers,
                  Rosemary
                  My build so far
                    last photos for today,
                    we were really lucky the guys that delivered the concrete for the slab had a job a couple of streets away and brought the leftovers around for us to use filling the cores. always worth asking
                    Cheers,
                    Rosemary
                    My build so far
                      Hi Rosemary,
                      Good luck with the build. It is a great experience, with the end result well worth the effort.
                      I only used a single wall stainless flue as my oven is outside. I think the double wall is more for when the flue needs to go through a ceiling/roof.
                      Performance wise I don't think it makes a difference.
                      Craig
                      "All I ask is the chance to prove that money can't make me happy"
                      Spike Milligan
                      "It is only impossible if you stop and think about it"
                      The Pirate Captain
                        The flat bars wont hold much, they will just sag.
                          Hi Rosemary
                          I agree with Brickie. You might need to weld another piece so it makes a T. This will add strength to the steel. then rebate them into the blocks. That's what I did but with Hebel. Flat steel has little strength.
                          Cheers Colin
                            Gudday
                            That steel looks too big to be store bought for the project so all talk of the steel aside what's the plans for the top slab? Hebel or poured?
                            Like the look of the base so far after building a single entry one, the multiple entry style is a big winner in my book
                              Heabel for the base on top of the steel. It isn't store bought but cut for me by a local fabricator. Hope it work???? It's quite a bit stronger than the stuff in the plans and the hebel has reo, though small, in it as well. Yeah very happy with the base. Two storage areas made more sense to us. Plus added strength under the central part of the oven.
                              Cheers,
                              Rosemary
                              My build so far
