mrchipster, a very good thought. :b: I can't wait until its time to do the cap!
UtahBeehiver, thanks, and yes Gary will be a winner in all this.
If he knew he would be much more excited about the project!brickie, that's a great idea, and much better than my flue plan. I could, using bricks, build a 'brickie flue' on the actual brick dome which follows its contour until its on top of the dome then build straight up from there and out the top of the onion. Now that's
!The brick of the dome will get heat from both sides as the brick of the oven will face the fire on one side and the brickie flue on the other. I assume that some of the heat from the flue will radiate back into the oven itself.
I have some flues ordered, I'll put plants in them!
Once again brickie, an elegant solution. Thanks!
you'll definitly get a full pig or I recon 2 in there.
