Hi, I would like to track down a metal fabricator in the Adelaide area (preferably the Hills) to make the front opening arch support. Do any of you other Adelaidians know a good one? Also What is Poorman's mortar?
Metal Fabrication Adelaide Area
Re: Metal Fabrication Adelaide Area
Billkidd,
I believe they gang is talking about what us yanks call Homebrew
3:1:1:1 sand, fireclay, lime, portland cement. It has been used quite a bit by builders in this forum. I used it in my build. Is it a topic of debate on the forum, just search for Homebrew and you get the answer. -
Hi billkidd,
to me provided that you do it properly with room for the metal arch support to expand at a different rate than the surrounding refractory brickwork, I see no problems at all as I put in an arch supporting my oven, not to support the arch bricks, but to hinge the cast aluminium doors.
I have pulled the pictures from my build or you can check them out at:
the angle iron supports are a loose fit in a wider groove cut into the dome bricks and can move independently without problems.
Where abouts in the Adelaide hills are you located?
Almost any handy person with a hammer and welder can make one similar.
Cheers.
Neill3 PhotosPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
http://www.fornobravo.com/forum/f35/...rway-4591.htmlComment
