Hi, I would like to track down a metal fabricator in the Adelaide area (preferably the Hills) to make the front opening arch support. Do any of you other Adelaidians know a good one? Also What is Poorman's mortar?
Metal Fabrication Adelaide Area
Re: Metal Fabrication Adelaide Area
Billkidd,
I believe they gang is talking about what us yanks call Homebrew
3:1:1:1 sand, fireclay, lime, portland cement. It has been used quite a bit by builders in this forum. I used it in my build. Is it a topic of debate on the forum, just search for Homebrew and you get the answer.
Hi billkidd,
to me provided that you do it properly with room for the metal arch support to expand at a different rate than the surrounding refractory brickwork, I see no problems at all as I put in an arch supporting my oven, not to support the arch bricks, but to hinge the cast aluminium doors.
I have pulled the pictures from my build or you can check them out at:
the angle iron supports are a loose fit in a wider groove cut into the dome bricks and can move independently without problems.
Where abouts in the Adelaide hills are you located?
Almost any handy person with a hammer and welder can make one similar.
Cheers.
Neill3 PhotosPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
