Re: New build in Adelaide - total rookie in need of help!
Back to the stand picture in post #24 from n8huntsman...I'm not so worried about the clearance to the fence as the alignment of the chimney and the apparent wood structure above. Are you going to do a back slant chimney to clear the overhang?
Dodgygrog - Have you talked to your neighbor and made sure they understand they will be on the invitation list for future pizza parties? Letting them be involved during the build might prove to be a really good idea. And as noted earlier, before you continue check the local construction/council codes against your plans.
Even if you need to get a variance/exception, I suspect if you can get someone in authority to put his/her hand on the outside of a completed (& insulated
) WFO in the Adelaide area when fired to pizza temps, they'll quickly realize it's less a hazard than somebody lighting off a barrel of trash
