Hey guys,
You may remember my first build with a 2nd hand modular oven:
I have since moved house and so must do everything all over again:S
I am now posting in here instead of the modular thread though. The Vibrok is not moveable so doing a brand new build.
The area I plan to build in is ready to go. It is all under patio cover which is great, plenty of room. I had a corner I just filled with concrete (pre-pour photo attached). Oven is on a pallet ready to go.
My current design decision is which way to go about building the base.
I had planned to keep costs and difficulty low by building the base out of dry stacked grey besser block and using hebel powerboard for the hearth.
Unfortunately there are a few problems with this - namely the gaps between the blocks as they allow 10mm for mortar. Is there an easy way around this? I need to keep standard sizing so that the Hebel board size fits square with the area. I would then pay someone to have the structures all rendered.
The other option is to do what I did previously - GB masonry blocks, mortared and a concrete hearth.
This however is more expensive as the blocks cost twice as much and I need a brickie to lay them, the concrete hearth is also more expensive than using Hebel. While I save on time by having a brickie do the blocks it also means doing formwork etc. for the suspended slab which I wouldn't need to do with Hebel. Lastly another problem is I need an extra tiled bench area - I planned to lay tiles on a hebel panel (which would have the sides rendered) - cheap and easy. I can't do this with the GB blocks method though as the hebel board wouldn't be finished like the blocks.
It seems both methods have their pros/cons. I would prefer to do the first method with dry stacked blocks but the gaps in the blocks seems like a huge pain.
The oven is a Vesuvio FVR80. A modular Napoli style 80cm internal (32 inch) Italian built oven.
