New build in Sydney
  • carioca
    • Sep 2006
    • 266
    #16
    Re: New build in Sydney
    Looks like a serious bit of work, mate! Good wishes for the New Year!
    • BrendanLovesPizza
      • Jun 2012
      • 98
      #17
      Thanks mate. Same to all on the forum.
      The build has started. 40" pompeii. With mosaic tile exterior.
      https://www.facebook.com/media/set/?...1&l=dcdb2f715c
      • BrendanLovesPizza
        • Jun 2012
        • 98
        #18
        Got the dome arch kinda sorted, a few of the angles played with my head for a while. Nothing a little mortar wont hide later.
        • BrendanLovesPizza
          • Jun 2012
          • 98
          #19
          Happy new year all!!!
          No wife no kids got some stuff done, holidays are great in the aussie summer. Hot but not too hot. Cricket in the background. Good times.
          My fire bricks for the oven are recycled from an old tiln so working them perfectly into postion is becoming quite a task, but over all quite happy so far with the build. Never used mortar for anything before this is a new learning curve.
          • Greenman
            • Feb 2013
            • 1123
            #20
            You are well on the way to smelling the pizza and the other good things. Looking good.
            Make hay while the sun shines.
            Cheers ......... Steve
            • oasiscdm
              • Jan 2012
              • 1239
              #21
              Hey Brendan
              Am curious why you beveled the inside of your inner arch bricks on the inside front?
              What is your theory on the door having done this? as it may make the reveal and sealing the door somewhat tricky.
              It does look good though...
              Cheers Colin
              Oven 1 Completed
              Oven 1 and surrounds
              • BrendanLovesPizza
                • Jun 2012
                • 98
                #22
                Dont really know Colin. little bit in me thinks the smoke will escape faster, the other bit in me thinks its going to look like a better transition to the chimney arch. Then another little bit in me was drunk when I made a test cut and liked it so I just ran with it. Always wanted a slightly different build to all others, maybe I just got my wish! I got some recycled Calsil bricks, may use a full length brick for the chimney arch not the notched part like you see here. I like the Calsil 'whiteness', I know it will discolour over time but for now it looks good.
                  • 2848
                  #23
                  G'day
                  From the pics the outer entrance and the oven mouth seem to be the same size? Please correct me if I'm wrong. That will make it very hard to fit a door as you have to get it past the outer. Tzcar has a 2 piece door I believe for this reason.
                  If your not to advanced you might consider re designing the entranceway say 50 mm oversize to the oven mouth. You'll still get revel this way and a seal for a door. The cut to the entrance brick will make you door a different shape but has the advantage of lessening the chance of chipping the entrance which can happen easy enough.
                  • BrendanLovesPizza
                    • Jun 2012
                    • 98
                    #24
                    Yeah dave. Going to make the decorative arch larger. The chimney arch bricks will have the notch removed like you said to make it bigger.
                      I may have misunderstood. But, if those "Calsil brick" are calcium silicate they have no structural integrity for the use that you have pictured. The "discoloration" wont be a problem. It will fall off into your food .
                      • BrendanLovesPizza
                        • Jun 2012
                        • 98
                        #26
                        You saying calsil bricks are no good for a chimney arch with a stainless flue
                        • oasiscdm
                          • Jan 2012
                          • 1239
                          #27
                          Yep you can't use them for that purpose. the flue Needs a solid support base.
                          Still curious about your door design drunk or not
                          Going to be very difficult to seal the door. I would consider losing the bevel. I know that is a lot of work but even I knocked done my flue gallery having completed it as it was not deep enough.
                          Cheers Colin
                          Oven 1 Completed
                          • BrendanLovesPizza
                            • Jun 2012
                            • 98
                            #28
                            I dont think these bricks are calsil. I may have made a mistake in there composition. I will do more research. The door seal will be fine guys. Trust me.
                            • oasiscdm
                              • Jan 2012
                              • 1239
                              #29
                              How heavy are they. If the weigh similar to your fire bricks then they will be fine to use.
                              Cheers Colin
                              Oven 1 Completed
                              • BrendanLovesPizza
                                • Jun 2012
                                • 98
                                #30
                                They are heavy. Just a different composition to a normal brick.
