Sealing the entry
  • applor
    • Oct 2013
    • 210
    Sealing the entry
    Hey guys,
    Despite being undercover, it seems I must seal the front entry, otherwise water pools on the slick tiles and can fill up and then pour down the front entry into the insulation below.
    Due to the temperatures at the entry, my 2 options as I see it are:
    1) High temp gasket silicone. Pretty easy but bright red in colour:/
    2) high temp mortar. Pretty easy and solid but does it soak up water?
    Which option do you guys think?
    Re: Sealing the entry
    If your oven is under cover you shouldn't need to bother preventing water entry.
    • applor
      • Oct 2013
      • 210
      That is what I originally thought but we've already had two decent downpours and as you know rain doesn't tend to fall straight down so water always gets onto the tiled area and then fills up around and into the entry.
      Luckily on both instance I put towels into that entry area but even the large one was absolutely soaked through. We're talking at least a litre of water has ended up on that area and if I hadn't towelled it, that water would have poured straight down into the insulation.
      tldr;
      It has to be sealed.
        I've designed the supporting slab for my ovens to slope away from the oven all the way around for this very reason. Is it possible to reset your granite slab with a slight slope? Because your oven will be heating up and down and therefore expanding while bits around it are not, you will have to go with something flexible like the red high temp silicone.
        • applor
          • Oct 2013
          • 210
          Yeah unfortunately no way I can slope the front marble tile.
          I know what you mean about heat expansion, though the actual cooking hearth is free floating so it can expand in and around the dome but sounds like I'll have to go with the high temp silicone and hope it looks OK and holds up OK.
            • 2848
            G'day
            One thing that will help. Tape down both sides of the gape. Use your seal, then remove the tape whilst it's still wet. You get a good straight edge that way
              G'day
              Yes, but make sure you remove the tape straight away. That red silicone dries really fast. Don't perform the operation if the area is in direct sun or it will dry too fast and you won't get a clean edge.
              • applor
                • Oct 2013
                • 210
                You wanted to know why it needed sealing?
                Picture tells a thousands words:
                • Greenman
                  • Feb 2013
                  • 1123
                  I have some kids in Brisbane and there are plenty of stories from the storms this afternoon. Nasty if you were in the path.
                  Dry as a chip here.
                  You are right. It pays to plan for the extreme and then the rest makes for no issues.
                  Cheers ......... Steve
                    • 2848
                    G'day Steve
                    I don't think we will hear from applor till tomorrow at the least. Applor lives in the path of the worst of it . I'm hoping he is just one of those 90 Thousand without power and that will be has not been effected more than that.
                    The damage to electrical network is such that they cannot restore much till tomorrow morning. The priority tonight is to make safe the fallen power lines and people are being told to stay inside their houses.
                    Many schools are to be closed tomorrow, and the armies being mobilized tomorrow.
                    Its just a case of waiting till daylight till we find out the full extent of the damage.
                      Maybe some of those thick clear plastic walls that roll up, like restaurants use, might be a good solution.
                      • applor
                        • Oct 2013
                        • 210
                        Hey guys!
                        Thank you all for your concern. While it was violent here we were lucky enough that we suffered no real damage and did not get the giant balls of hail.
                        I actually sealed the entrance and the alum edging a couple days ago so this weather was a very prompt test of how it held up.
                        I believe the front remained sealed, though I am sure a little bit of water may have gotten in but that can't be helped. I also get a bit of rain down my flue.
                        I was actually thinking yesterday that some of those clear Perspex weather shields might be a good idea, just one on each side to the corner.
                        The main problem is actually the guttering - the patio shares the one downpipe with the rest of the roof in that area and it can't handle it.
                        As a result, all along that edge the gutters overflow and pour over the side as you can see in that picture. Need to address that I think and it will help reduce the amount of water that gets onto the oven bench top.
                        • BrendanLovesPizza
                          • Jun 2012
                          • 98
                          what about giving the oven a rain coat for the entrance.
                          My oven will not be undercover so am thinking about making a rain coat for the entrance.
                          Should divert all the water away with ease.
                          The build has started. 40" pompeii. With mosaic tile exterior.
                          https://www.facebook.com/media/set/?...1&l=dcdb2f715c
                            Originally posted by applor
                            Hey guys!
                            Put in another down pipe. Inadequate design in order to save money is usually a recipe for more work later on.
