Hi all,
I'm trying to source some ceramic rope for a thermal break between the dome arch and chimney arch. I'm based in Sydney so are there any local suppliers that sell by the meter as I don't need a huge amount. Another option is put insulating blanket between the arches, is this ok?
Also what high temp silicon has the forum found to be a good product, some are rated to 360 deg c some only 300, but apples aint apples with high temp silicons. I've found gasket glue to be the best option but is not very visually appealing and would have to hide with the ceramic rope.
I'm also after an urban wear pipe type chimney with decorative top would standard plumbing pipe do or do I need to source a higher temp rated clay pipe? Suppliers? Seems very hard to find in Sydney.
Thanks all.
Thanks all.
