Breaking ground !
  • BBQBOY
    • Sep 2014
    • 20
    Breaking ground !
    Hello started planing on building a oven a few years ago but haven't got there yet . Yesterday there were contractors in my front yard with a excavator flicked them sum cAsh now I have a nice flat spot to begin the build guess I better learn how to lay bricks mix concrete and make a pizza oven , the wife is impressed with the big hole and pile of dirt in the middle of the yard
  • RandyJ
    • May 2010
    • 1191
    Congratulations it feels good to get started. Make sure to ask a lot of questions and post a lot of pictures. We are all here to help.
    Randy
      Water wicking up from the foundation slab and into the stand can be a problem, so it is a good idea to finish the foundation slab slightly higher than ground level to discourage water pooling around the base.
      • NCMan
        • Jan 2014
        • 846
        Very good advice. I would add in a suggestion of incorporating a vapor barrier under the slab, also. Hopefully, you plan on some clean gravel under the slab as well.
        My Build:
        • Wozza
          • Apr 2014
          • 141
          Looks like that's street frontage behind where you are building it. Is that your front garden?
          • philby303
            • Jul 2015
            • 23
            hehe that would make for brilliant street parties
            • BBQBOY
              • Sep 2014
              • 20
              Yep putting it up in the front yard ,the back yard has big dogs that would like pizza a little to much , there will be a fence up before I start cooking to keep the neighbours out !! Cheers for the info on ground levels +water issues very helpful . Driving down the road today sign said free stuff nice bit of a marble with hole for a sink just what I needed and the right price
              • Wozza
                • Apr 2014
                • 141
                Originally posted by BBQBOY
                Yep putting it up in the front yard...
                Have you checked with any local regs that might cause you problems? There's a limit to what I can do to the front of my property. Not that I have the room to build one out the front of my place, but if I did, I'm pretty certain that I'd need permission. And I'm pretty certain that I wouldn't get it. Apologies if you've already checked, but I'd hate to see you having to tear it down because it wasn't approved.
                Nice piece of marble, by the way. I think I would have taken that and then worked out what I could use it for later.
                • BBQBOY
                  • Sep 2014
                  • 20
                  Called the council they were as helpful as a fart in a space suit , need to contact a building certifer and see if they know any information on this kind of project cheers for the heads up
                  • Steady
                    • Feb 2015
                    • 214
                    An excellent find - I've been watching GTree for something similar
                    Cheers,
                    Steady
                    http://www.fornobravo.com/forum/f51/...ild-21760.html
                    • BBQBOY
                      • Sep 2014
                      • 20
                      • BBQBOY
                        • Sep 2014
                        • 20
                        Been a few months but it finally happened fence is up slab is down now to lay some bricks
                          • 5260
                          Great to see you get started. Your summer I hear has been really hot. So a good cold brew must be a priority........where you going to use the marble, landing, keystone, side table?
                          • BBQBOY
                            • Sep 2014
                            • 20
                            A few brews were consumed after that day's work it was bloody hot . In regards to the marble it will be used to the side with a sink attached for prep ect ect
                              • 2848
                              G'day
                              Sounds like the whole outdoor kitchen is on the cards?
                              What are you plans to date.
                              Just up the track at Manly West, it's good to see a Brisbane build again.
