After a long illness I have finally started to build a bread oven for our new WFO and cooking classes,
The oven needs to be built first before we close in the 9metres x 5metres room, only the entrance of the oven will be in the kitchen with rest of the oven outside.
With the floor height 500mm of the ground we planned a platform to sit on 4 concrete pads to take the 1.75 ton oven
The oven will be a barrel / vault oven measuring 1060mm wide by 1295mm long, wall and hearth thickness of 115mm and fully insulated
First we cleared the area and measured out the footings each at 400x400x400mm I made up a frame and marked out the position of each of the footings then dug the holes and put the frame back down before pouring the concrete
