New member, new build.
  • The foxdale phantom
    • Mar 2026
    • 28
    Hello all, embarking on a wood fire oven build. After many camping trips with friends who have a shack by the river with a wood fired oven where many a culinary delight has been produced I have decided that we need one at home.
    Have watched many YouTube videos and in the process of researching had found this great forum. Have been reading quite a lot and have found many great pointers. Will start another post asking questions and advice.
    Planning on a 47 inch , in a corner position.
  • Giovanni Rossi
    • Mar 2021
    • 310
    You've stopped at the correct site. I had a fair amount of construction skills, but without the guidance, wisdom and experience of this group, my build would have turned out much differently (probably not in a good way). I was all set to build a barrel style using plans from a guy in Aus following a friend's build when I found FB Forum. I had the time during the pandemic shutdowns to read through years of posts here. What an education. And, it was really interesting to see how the craft has evolved.
    • JRPizza
      • Jan 2012
      • 1557
      47" finished diameter, or 47" internal? That big of an internal is going to be a pretty big oven for home use!
      My build thread
        • Mar 2026
        • 28
        Yah was planning 47 internal , have the space. Big family so plan on doing some big cooks in it. Roasts, breads, pizza ect.
          • Mar 2026
          • 28
          Tried searching the forum with no luck but has any done or recommended building a raised shelf inside the WFO ?
            I tried a raised shelf in my oven once, when baking bread rolls using the retained heat ie door closed. It was not successful with the bottom level not cooking at all well. My conclusion was that because these ovens cook by radiating heat, the pan sitting on the shelf prevented radiant heat from reaching the rolls on the bottom row. With no fan assistance heat by convection also failed to reach the bottom level. I’ve not attempted it since. Brick bread ovens only have one row and a very low roof, which also explains the lack of multiple shelves in these types of ovens.
            • Backyardchef
              • Mar 2026
              • 10
              welcome, sounds like a great plan,good luck.
                • Mar 2026
                • 28
                Where’s the best and nearest to source FB and Insulation board in Nth. QLD ?
                  • Mar 2026
                  • 28
                  Scored some tiles from marketplace to lay on the bottom of hearth .
                    • Mar 2026
                    • 28
                    Got excited and started a mock up on the shed floor. Happy to take any criticisms on what I’ve laid out thus far. I’ve noticed from posts that I’m doing mine a little in reverse as the covered area will be built first and then WFO installed after.
                      • Mar 2026
                      • 28
Name:
ID:	473437 Photo of BBQ/entertainmment/WFO area progress. I have delved into the Newbies archived post and have found a great deal of inspiration. Love the larger sized WFO of Karangi Dude’s and am pretty sure I’ll follow SableSprings Y shaped oven stand for my corner build. Where SableSprings utilized the space on either end for carts I’m picturing the continuation of right hand side to be a bench and the left will be fire wood storage with possibly a door (to keep snakes out or in ) . Visualising a timber beam across the front in place of the angle iron.
                      is it possible for admin to move my thread to the Australian builds section ?
                        • Mar 2026
                        • 28
                        Q’s , with my corner build one edge will be against a full height block wall, what’s the consensus on reinforcing the slab for the hearth to the block wall with say reo -bar?
                          Most probably, (just guessing) that the block wall's cells are not filled. That may lead to the hangers failing due to shearing. I would lay 4" wide paver blocks on edge or a wall of brick for support from underneath. Regardless, if the cores were filled, that would probably be a quicker fix than drilling into the existing block wall to "hang" the rebar.
                            • Mar 2026
                            • 28
                            Gulf block wall will be core filled , have added some reinforcement in the slab back right corner to take the weight of the WFO.
                              • 5260
                              I moved your thread as requested. However, you get more views if the thread is under Pompeii Builds. Karagi Dude made some two great ovens and showed what cooking could be done other than pizzas. Sadly, we do not hear much from him anymore.
