Recipe for lightweight strong oven base??
  • edjc
    • Nov 2013
    • 14
    Looking for recipe and ratios to mix vermiculite and concrete for a strong yet lighter oven base for which to put base cooking level brick then build dome oven on top from there.
    I've Heard it may be 5 to 1 ratio vermiculite to concrete
    Re: Recipe for lightweight strong oven base??
    You might want to clarify that question with a little more of an explaination of what you plan to build. 5 to 1 vcrete is recomended as an insulation layer for an oven floor. That is, if it is placed on top of a structural layer. It has plenty of "compressive strength", but no "tensil strength".
    • boerwarrior
      • Apr 2013
      • 454
      Gulf has it right - you can't suspend a "vermicrete" floor on top of a U-shaped base.
      • edjc
        • Nov 2013
        • 14
        My vision is to Place the vermiculite and concrete Mix the base on this wooden structure. From this base I will layer of my firebrick base and then build up the firebrick dome
