Re: Slow Cooked Meats
Hi Jim,
I have had good success putting slow cook meals in the oven overnight, with a start temp in the low 300's. My oven will cool down into the mid 200's and be in the low 200's or high 100's by the next morning.
I faintly remember a conversation about cooking meats, where the food temp never exceeds 200 degree's (or there - about temperature wise) as a temperature above 200 will do something to the protein, or the connective tissues and toughen the meat... Incentive to cook in a water bath, in a pot without a lid (the temp won't exceed the temp of boiling water) and keep from making the meat tough...
Some of my favorite meals from the oven... slow cook..
JED
Slow Cooked Meats
I usually shoot for putting roasts and such in the oven at 350-375 or so which typically gives about a five hour cooking time. But time is basically a function of temp. The food will significantly depress the oven temp for a while and it will typically cook at a temp somwhat below where you started. On occasion I put things in at 300 or so and find they can be in the oven for 8 hours with no upper limit that I have found. The oven just keeps getting cooler!
As an aside, my father-in-law used to do pot roasts at 150 degrees for 24 hours and they were very good.
Good luck!
Jay
Slow Cooked Meats
I finally got around to trying my slow cooking techniques on a couple of meats. A chicken in a cast iron pot, covered, using my lemon inside recipe.
A leg of lamb in an open dish with the rosemary garlic marinade.
Did them after pizzas the day before.
Threw them in, temporary wood door, came back in 5 hours.
Both were excellent but they still cooked faster and better than I thought they would.
Next time I'll try with an even cooler oven and longer time.
I'm thinking about an 8 to 12 hour bake at very low temp.
Anyone doing that?
Next, maybe a big butt.Tags: None
