Terracotta bakeware
  • Xabia Jim
    • Dec 2006
    • 1168
    Terracotta bakeware
    I notice that FB sells some Italian terracotta bakeware and highly recommend it for your wood fired oven if you're going to bake or slow cook in it.
    Yesterday I was searching ceramics shops in Gata and ran across a pile of rustic terracotta dishes. They were obviously hand made and had a rough texture to them. There were in three very dusty piles, with each piece separated by cardboard. We bought 6 pieces!!
    They are heavy and guaranteed for wood fired ovens. My favorite are the oval ones which have a pouring spout on one end and a clay chunk handle at the other end....allows you to drain off the fat and juices!
    The round flat one is interesting. I thought it might be fun for a pizza server. It's glazed....could it be a pizza stone? My pizza stone is unglazed....have you found glazed pizza stones?
    Now comes the cooking test....
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    Re: Terracotta bakeware
    Hey Jim,
    I think you are going to really enjoy your bakeware -- there is something special about terracotta in a wood-fired oven. I think it has something to do with the way terracotta makes a moist, gentle heat.
    I've read that soaking your bakeware for an hour before you cook with it the first time helps cure it and minimized cracking.
    Enjoy.
    • Xabia Jim
      • Dec 2006
      • 1168
      Thanks for the tip, I'll try the soaking.
      • Xabia Jim
        • Dec 2006
        • 1168
        By the way James, I was in one of the local ceramics stores and there was a sign above the terracotta bakeware recommending soaking for 24 hours before using (the first time?). So that's what I did with the new stuff. Can't oversoak it I guess!
