Asking about the high end pizza peel with the perferrated holes, is it necassary ?
Re: Pizza peel
Is it necessary? No. Are the perforated holes helpful? I think so. Excess bench flour can burn and be bitter. The perforated holes will shake some of that flour off. If you're really careful with how much flour you use and work quickly, you shouldn't have any excess bench flour, but the holes are a good insurance policy.
Re: Pizza peel
I have this one:
The Ultimate Pizza Peel 14.6" :: Pizza Peels & Oven Tools :: Forno Bravo Store
I absolutely LOVE it.Ken H. - Kentucky
42" Pompeii
Re: Pizza peel
Does anyone know the thickness of the steel on their peel? I am ready to make my own - self sufficient you know. 0.125 is way too heavy for stainless!
CW
Re: Pizza peel
CW, I made mine from 16 ga. aluminum. It comes in around .05 in. Steel for the same gauge is around .06 in.; don't know why. (I use wood to get the pizza into the oven an the metal to move / remove it for what it's worth).Check out my pictures here:
Re: Pizza peel
In a land where we use sensible measurement .05 in is 1.2mm I used to make stainless steel peels from 0.9 mm 304 stainless steel, but now go a bit thicker to 1.2mm as the thinner ones were a bit floppy.the down side is that every time you put the peel into the oven it heats up fast which in turn is taking heat out of the oven.
The thermal conductivity of aluminium is way higher than that of stainless steel so in this regard the stainless is superior. i also don't like the way aluminium abrades so easily.Last edited by david s; 04-13-2012, 10:33 PM.Kindled with zeal and fired with passion.
Re: Pizza peel
It's not necessary but I opt for it cause it makes the process easier
Re: Pizza peel
Looking at a supplier in Italy, they seem to have both aluminium and steel:
http://www.ziopepe.net/documents/Cat..._Pepe_2011.pdf
