Re: Playing with sourdough
Here's my starter after a few days of doubling the concoction.
It was nice and bubbly. Seemed pretty active.
Here are some pics of my experiment.
I must admit the bread came out looking excellent and had great texture.
But........ I thought the flavor was a bit dull, although it was sour and I got a good rise.......... I think it may have been lacking in salt.
I usually just make my bread dough without measuring and this batch was a bit larger than my normal batch and I was afraid to over salt it.
Jim,
Many restaurants now serve soup in a sourdough bread bowl. My goal is to be able to make good round sourdough bowls by this winter. I've had one attempt and it was a complete flop. My starter was only 4 days old and I was impatient about the whole thing I guess. I'm trying again tomorrow with my 3 week old starter. Any tricks to making my small loaf stay round without putting it in a pan? Thanks, Karen
Asdavew,
Good luck with the bake. You're hooked now, so there's no turning back. An interesting ancient quote, courtesy of Forum member Alphonse, "Fifth century Byzantine proverb, ' The nation with too much bread has many problems: the nation with too little bread has only one problem'."
Jim
I set out a bowl of equal parts water and flour on the fridge last Friday. After 2 days it was already bubbly. So every day after that I poured half out and added the same in flour and water. Then on Wed. I started to just add, no subtraction. Probably doubling the mix every day.
Today, (Sat.) I had a big bowl full. All bubbly and stinky!
(good stinky) So I took half out at 2:30pm. I added more flour, a bit of oil, salt, and a small amount of sugar. I mixed it in my mixer and added flour till it was just a bit sticky. Then I hand kneaded it for about 15 minutes. I used the window pane test and it looked good. So I let it sit for 3 hours till it doubled. Then I separated it into three pieces and put each piece in a loaf pan for a final raise..........That's where I am at now.. 6:15 p.m. I will cook it in a few hours hopefully.
I took plenty of pics and will post them when the batch is done!
Drake,
I've quadrupled a pound with good results, but it takes longer: 16-18 hours. I wouldn't go much further than that for one feeding.
I think we might all be overlooking one thing: starters vary because wild yeast strains vary, envirnoments vary, kitchens vary, water varies, flour varies, etc., etc. That's why it's difficult to write hard and fast rules on starters.
Jim
Drake,
You're spot on with the wet versus dry environments and the effects they have. This is one area that lets you manipulate final flavor. Depends on taste and what you're after.
Dutch,
Because you're using a firm starter, I think your method should work just fine. It comes down to that Crucial area of controlling temps. The best and clearest explanation in this area that I've found is in Bread by Jeffrey Hamelman. However, it finally rests with the baker and his or her experience, equipment, tastes, ingredients. It is entirely possible to make a firm starter from a liquid one or vice versa. My own preference is for a liquid one, but that's just me.
Jim
and an interesting note on "obsessive feeding"
How much starter do I need to keep?
and a note on rising times
How do I get holey, sour, moist and long keeping bread?
And here's an opinion in favor of activating the sourdough - but still no good explanation why you cannot just give it time to activate in your bread dough during a longer bulk ferment!
How should I feed my starter for best results?
Drake, that's a good point, although in my case I have followed advice Jim posted here once about pancake batter starter leading to pancake like bread (or something like that). My starter is a bit lower hydration than my 65% hydration bread dough. When I feed my starter I leave it on the counter for about 4-6 hours, then it goes back in the fridge. It's usually pretty active for about 3-4 days, then it quiets down a bit. I'd love to know if you are right about the hydration of the starter affecting the sweetness of the final product. I wonder if you maintain similar hydration for starter and dough whether the feeding to activate issue would be moot then? On the other hand, since starter is a mixed culture of lactobacilli and yeast, maybe having a higher hydration growth phase somehow selects one or the other of these in a way that is helpful to leavening and flavor. Here's a technical article that goes into some scientific background on this subject.Originally posted by DrakeRemoray View PostMaver, I think there is a difference in letting the starter ferment longer vs letting the bread rise longer. The latter is a drier environment favored by a different type of bacteria than the wet environment of the starter. I believe, that a longer, drier, fermentation will result in a more sour flavor, while a longer wet environment will result in more sugars that help with crust development. I may be out of my league now, but I think that is the difference between Acetic (sour and dry loving) vs Lactic (sweeter and wet loving) acids...
How do lactic bacteria affect sourdough bread?
Interesting read - not sure if it answers these questions though.
Regards,
Marc
Does not go directly back into the fridge it will stay out and ferment much like a regular dough. Since ours is firm it does not get bubbly like a barm or more liquid starter. In feeding we usually try for about 60% hydration much like in our final dough.
Best
Dutch
Do you feed it and put it directly back in the fridge, or do you let it sit out until its bubbly?Originally posted by Dutchoven View PostWe use a mother dough, much the same texture as most preferments. It is fed directly from the fridge and usually just double 24 to 48 hours before using...we don't feed it obsessively at all...2 or 3 times per week as my baking schedule is usually for Wednesday and Saturday markets. It is allowed to ferment at room temperature for anywhere from 6 to 10 hours.
I wholeheartedly agree with Jim in controlling mixing times and temperature are crucial...with a capital C.
I know that this may be a bit of a stretch but...and that is a big one...I have on occasion refridgerated the dough after the primary fermentation and added cold dough as well as cooler water to create the final dough and had great results. In that case I have no worries about the dough becoming too warm during mixing and kneading. The extra time in fermentation is really no inconvenience.
Jim, what's your take on that?
Best
Dutch
Best
Dutch
Earlier today I took 1/2 of the starter I usually use and added 1/4 wt water, 1/4 wt whiteflour/rye mix. Once its nice and frothy I'll use it to make my barm, and then the bread....either Fri evening or Sat morning. Hopefully things will be more active than usual.
This is an interesting discussion. Hopefully it will lead to a more relaxed feeding schedule for my starter(s) in the future...
Jim, are you able to more than double your starter when mixing it up from the fridge? How much more than double do you think is acceptable?
Again, I am not exactly sure, but this is what my reading has led me to believe, that the overnight retardation is the dry loving, sour flavor producing phase of my particular bread schedule...
Baking again on Sunday, my Mother in law is in town and she has her own ideas about baking so...
Drake
